I have a SOP-18 IC (0.65mm pin pitch) which I need to identify. It seems the vendor removed the labels on top of the IC, so I need your help.
The IC is usually connected to a bunch of LEDs and two pins are connected to an epoxy blob (I guess a MCU). I assume the IC is some kind of shift register or LED driver, but I would like to know which one exactly. Based on the number of pins and location of the GND and VCC pin I could also assume it's a PIC MCU, but just for controlling LEDs, that would be an overkill imho...
Attached I have pictures of the IC top and bottom (with some codes "T6AL7CFF0074-2" and "VO8") and a schematic how to IC is connected on the PCB. Under the IC on the PCB there was the code "8A21" printed on the silkscreen.
I hope you can help me to identify this part.
Thanks!!
Edit:
A little bit more information on the device in which the IC is integrated:
This devices has 10 LEDS connected to the "unknown" IC. The IC itself is connected with two pins to an epoxy blob which is probably the microcontroller of the circuit, because this blob is also connected by USB to the computer. This is why it's hard for me to believe it's a PIC.
I analysed the pins 16 and 13 which are connected to the MCU and I can say, that pin 16 seems to be some kind of Enable pin. As long as this is High, nothing happens on the LED ouputs. If pin 16 is low, signals on Pin 13 seems to be relevant: Pin 13 receives High/low signals depending on how many LEDs should light.
For every low signal, another LED will be enabled. If there are no more LOW signals on pin 13, the LEDs will turn off (successively - one after another) - The number of enabled/disabled LEDs will update once every 450ms and only one LED at a time.
What's this device all about?
The device was originally sold as "typing trainer". It's connected by USB and on the computer there is a small application required to run in the background. For every keystroke you are typing on the keyboard a LOW signal is sent to pin 13 of the IC, telling the IC to turn on a LED. The faster you are typing on the keyboard, the more LEDs will light up. If you are getting slower or stop typing, the LEDs will go off (successively every 450ms).
If you need further information, please let me know.
