hi!
I have a board with BQ2031 chip on it -
datasheet.
It is on a board from: HP 348879-005 4.0 V cached battery for HP servers
I have replacement on order, but since I live in Norway it is a few days away. So Im looking for alternative solution - and it is extremely urgent.
First I have de-soldered all the batteries and connected to a DC supply in order to simulate healthy batteries. It didnt work as the board still was saying it was in a "Fault condition". It wasnt even trying our batteries or drawing any current from the batteries.
In datasheet it says following:
"If the battery voltage is less than the low-voltage threshold, the bq2031 provides trickle-current charging until the voltage rises into the allowed range or an internal timer runs out and places the bq2031 in a Fault condition."
I only need to this battery to work for 30-60 second - give away a "green" signal - in order for the server controller to boot. And I cant replace the batteries them self.
My question is:If I swap BQ2031 for a brand new BQ2031 chip will it by default start as "green" and boot up even if batteries are low or will it right away without delay enter a "Fault state" again?..
And is there any other way to "trick" this board into thinking it has new batteries?
