Author Topic: Please recommend an ESR meter - DIY kitset if possible  (Read 4490 times)
Offline nzo
« on: November 09, 2011, 06:29:56 pm »
I definitely doesn't have to be an expensive one :)
Thank you!
Frogman: half man, half frog, but which half?
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
Re: Please recommend an ESR meter - DIY kitset if possible
« Reply #1 on: November 09, 2011, 06:52:22 pm »
Oh, the joy of sending various electronics to silicon heaven
Offline nzo
« Reply #2 on: November 09, 2011, 07:00:15 pm »
Thank you smart-ass :)
I guess I was asking what YOU (the members here) recommend. Is that ok with you mate?
« Last Edit: November 09, 2011, 07:01:51 pm by nzo »
  • Country: hr
    • HackLordSniper
« Reply #3 on: November 09, 2011, 07:29:19 pm »
You are welcome  :)
I can reccomend one from GME instruments. I use it almost daily for few months now and it has paid itself many times allready. It is easy and intuitive to use, it can test in circuit, it has a nice LED scale with common capitances so you know is cap bad or good immeadately. Also it can test charged capacitors because it discharges the capacitor first, atleast its manufacturers claim but im not willling to test how good it works on larger capacitors, the design is easy on the battery and can use rechargable or wallwart (which you dont get, but its quite common voltage). However if you insist on a kit i cant suggest you anything since i dont have experience with it and you can not build something so compact with nice case and all except you are willing to spend more money than in ready made instrument.
« Last Edit: November 09, 2011, 07:31:51 pm by hacklordsniper »
Offline Psi
« Reply #4 on: November 09, 2011, 09:06:48 pm »
« Last Edit: November 10, 2011, 11:31:55 am by Psi »
Uncle Vernon
  • Guest
« Reply #5 on: November 09, 2011, 10:54:00 pm »
Altronics kit.  No idea how usable it is. http://www.altronics.com.au/index.asp?area=item&id=K2574
Online kripton2035
« Reply #6 on: November 10, 2011, 12:06:28 am »
here on my web site, on the esr repository page, lots of schematics, open source for most of them
from the simplest to more complicated esr meters.
http://kripton2035.free.fr/esr-repository.html
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #7 on: November 10, 2011, 06:50:47 am »
You can make a DIY on the fly one using a scope and an FG:
http://www.anatekcorp.com/ttg/tiptrick.htm#Scope%20ESR
If you don't troubleshoot often the makeshift one can do.
http://fullnet.com/~tomg/esrscope.htm
Best Wishes,
 Saturation
Offline nzo
« Reply #8 on: November 10, 2011, 09:07:58 am »
Wow - thank you all! That will keep me busy. Really appreciate it.
