Electronics => Beginners => Topic started by: nzo on November 09, 2011, 07:29:56 am
Title: Please recommend an ESR meter - DIY kitset if possible
Post by: nzo on November 09, 2011, 07:29:56 am
I definitely doesn't have to be an expensive one :)
Thank you!
Title: Re: Please recommend an ESR meter - DIY kitset if possible
Post by: hacklordsniper on November 09, 2011, 07:52:22 am
Here you go my friend:
http://lmgtfy.com/?q=esr+meter+kit (http://lmgtfy.com/?q=esr+meter+kit)
Post by: nzo on November 09, 2011, 08:00:15 am
Thank you smart-ass :)
I guess I was asking what YOU (the members here) recommend. Is that ok with you mate?
Post by: hacklordsniper on November 09, 2011, 08:29:19 am
You are welcome  :)
I can reccomend one from GME instruments. I use it almost daily for few months now and it has paid itself many times allready. It is easy and intuitive to use, it can test in circuit, it has a nice LED scale with common capitances so you know is cap bad or good immeadately. Also it can test charged capacitors because it discharges the capacitor first, atleast its manufacturers claim but im not willling to test how good it works on larger capacitors, the design is easy on the battery and can use rechargable or wallwart (which you dont get, but its quite common voltage). However if you insist on a kit i cant suggest you anything since i dont have experience with it and you can not build something so compact with nice case and all except you are willing to spend more money than in ready made instrument.
Post by: Psi on November 09, 2011, 10:06:48 am
i dunno what price range your after, and it's not a kit but
 http://www.peakelec.co.uk/acatalog/jz_esr60.html (http://www.peakelec.co.uk/acatalog/jz_esr60.html)
http://www.peakelec.co.uk/acatalog/jz_esr70.html (http://www.peakelec.co.uk/acatalog/jz_esr70.html)
Post by: Uncle Vernon on November 09, 2011, 11:54:00 am
Altronics kit.  No idea how usable it is. http://www.altronics.com.au/index.asp?area=item&id=K2574 (http://www.altronics.com.au/index.asp?area=item&id=K2574)
Post by: kripton2035 on November 09, 2011, 01:06:28 pm
here on my web site, on the esr repository page, lots of schematics, open source for most of them
from the simplest to more complicated esr meters.
http://kripton2035.free.fr/esr-repository.html (http://kripton2035.free.fr/esr-repository.html)
Post by: saturation on November 09, 2011, 07:50:47 pm
You can make a DIY on the fly one using a scope and an FG:
http://www.anatekcorp.com/ttg/tiptrick.htm#Scope%20ESR (http://www.anatekcorp.com/ttg/tiptrick.htm#Scope%20ESR)
If you don't troubleshoot often the makeshift one can do.
http://fullnet.com/~tomg/esrscope.htm (http://fullnet.com/~tomg/esrscope.htm)
Post by: nzo on November 09, 2011, 10:07:58 pm
Wow - thank you all! That will keep me busy. Really appreciate it.
