Don't cry over the board use a handkerchief.
Replace the transistors with TO92 footprint transistors and use the board to do further testing.
The 74HC595 can't handle the current .
well, at least the MCU part with the power supply is working correctly with the programmer part. I just need to be happy
with what went good on the first try. It should have been a christmas present, and because I have to work, I won't have time to
source the needed parts. Also, I am not sure that the 74HC595s are working correctly, but I'll test that it later.
I now need a nice little frame with the title "F*cktard! Check the footprints!!" Any ideas?
