Hi guys,
does anyone knows of portable on/off pulse generator available in the market?
Basically, I have a inductive NPN/PNP sensor that senses the bolts of a rotating machine. A Frequency converter then converts this input into volts for monitoring purposes. It would be handy to be able to calibrate the converter without running the rotation machine. Btw, the system runs on 24Vdc.
I would probably use around the 20Hz - 500Hz range
