I am building a circuit with a Light Dependent Resistor and relay that will turn the lights off in a room when the natural light is sufficient to light the room. How do I position the LDR so that the electric light does not cause the LDR to cycle off and on? If possible, I want to have the LDR in the room. I may also add a PIR sensor and an OR Gate so that if no one is in the room the relay will also turn off.
