Ow, so the 200k is not really driving the zener
. Stupid me ... It doesn't provide enough current, right? So that's why when I put second multimeter the voltage changes
. So the 5k is actually driving the Zener relying on the far better output of the opamp, rather than the power supply. Well, that means that this circuit is no good for low voltage outputs. I thought I can put a divider in the input and have 1 volt instead of 10. Well I can do that, but on the output and I'll need a buffer.
Thanks!
