Do you have positive and negative power supply, or just this signal coming from a pair of wires?
Actually the output comes from a particular device (single wire) that gives positive and negative output. I need to alter this output to have longer pulse width (100ms to 300ms) that's all.
Yes, but if you don't have a +10v and -10v supply to drive your output 300ms signal, where would the power come from?
Is there a relative GND reference. Example, is the 1 source wire going +10v with the other wire to GND, and when you have -10v, is the +10v wire going to GND and the other wire going to +10v making the signal at the wire look like it's going from -10 to +10, then both wires at GND for 0v?
Or, is 1 wire a true fixed GND and the other having a 20v PP swing?
When you have 0v, is this an open signal, or, is it shorted at GND?
Also, how much current will you need to drive?
Could an RS232 driver with a +/-10v supply give your enough current? And for 0v, just disabling the output drive leaving the output at 0v sufficient?
