Hi All,
Got (hopefully) a simple problem, and trying to find a good solution before I buy parts. I've got one of those pre-made amplifier PCB's from ebay (this one:
http://www.ebay.co.uk/itm/231179156525), and also one of those 1A Car USB chargers, which I've dismantled to get just the PCB to convert the 12V to a 5V USB so that I can either charge a phone, or power in this case my Chromecast Audio.
With the Chromecast Audio in place, it has an annoying inconsistent buzz. With the Chromecast on it's own PSU, it works fine. Now my feelings are there's an Audio Ground Loop. The attached diagram is not very good (accuracy with symbols, or correct use), but demonstrates what I mean. I've shown it with the physical connections as I have it wired.
As I've ruled out the amp on its own, as well as the Chromecast, it's either a poor DC-DC converter (quite likely for £1), or there's the loop I mentioned. Any thoughts? I haven't a lot of room in the box I've used, so those tiny USB Car charger PCB's are kind of my maximum, and I'm not sure, but I think a 7805 might generate too much heat in such a small space with a 1A load.
Thanks for any insight anybody has.
