Author Topic: Potential Relay Replacement  (Read 1215 times)
Offline RyanGTopic starter
« on: February 19, 2017, 09:17:42 am »
I am trying to change out some of the motor starting potential relays we use at work. I was wondering if it is doable in solid state form. The relay contacts burn out fairly quickly with the number of times the motors turn on and off, probably a few hundred to a thousand times in a day. The relays run  on 120vac across the contacts and coil, and they are normally closed. I attached a random schematic from google search, but it is basically the same as what I am dealing with. I thought about using triacs, but I don't really know if I can make one act as normally closed without some significant modifications to the current circuitry. Everything does have to be done with 120vac.
Here is a link to a relay that is almost exactly the same as the ones we use. Relay
Online Ian.M
Re: Potential Relay Replacement
« Reply #1 on: February 19, 2017, 10:58:00 am »
If the motor's under 5HP, http://www.supco.com/supr&apr5.htm
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #2 on: February 19, 2017, 01:29:56 pm »
If you're really turning the motor on and off a lot I would use an VFD. It will also reduce the stress on the motor and shaft itself.
« Reply #3 on: February 22, 2017, 08:25:30 am »
How does this look?
Blue goes to my start capacitor and red goes to the start winding.
« Last Edit: February 22, 2017, 08:29:35 am by RyanG »
