I want to use a circuit like this as a hook-switch for a phone system (not connected to actual phone lines, just in the building)
Wikipedia says that the ring voltage can be up to 90V ac
superimposed on the -48V dc.
My question is if that 90V ac is centered or based on the -48V dc?
If the voltage is alternating between peaks of +42V (-48V + 90V) and troughs of -48V then I can use regular 2n2222s. If its between -93V (-48V - 45V) and -3V (-48V + 45V) Then I cannot use 2n2222s as they have a collector emitter maximum voltage of 60V.
