Glass microspheres, used as they are hollow and thus reduce the mass of filler needed and make the part lighter as well. Common in the fibreglass industry and in boat building to mix in with resin to make light but strong resin castings. Makes a much lower density composite which is still as strong and waterproof as the original resin. If they wanted to only bulk it up they would use ground glass, like that used in car body filler, as this makes it more bulky and allows it to be shaped afterwards by sanding and filing.
