Author Topic: power amp trys to turn on by its self?  (Read 1064 times)
Offline p5200Topic starter
« on: February 18, 2014, 01:22:21 am »
I had to replace two op amps on the input board of my power amp after loaning it out and when I got it back it had a few roaches in it.  :o  I replaced the CD4013B chip which is used for the pulse when pushing the power on/off switch and checked all other components on that small board. The amp has a trigger switch on the back for manual, audio signal input turn on, or 12v turn on input. I was wondering if maybe, one of the components on the small trigger board may be causing the amp to try to turn on when in off/standby mode. I was guessing maybe the 4N32 chip might be causing this problem? The amp works fine when turned on otherwise. her is a schematic of the trigger board any advice would be greatly appreciated!   :)
