Ok, that is actually clear.
I tried to make some verifications on another sensor, like the
NTCLE100, same graph and a maximum voltage defined to be no more than 50V.
At 55°C, at 50V I will dissipate a bit more than Pmax of 500mW (something around 770mW), so make sense to have a less voltage, since the 50V maximum is a top limit that shall never be reached.
But at 0°C, the Pmax allowed is still 100%. Making a trial, for the 10k part, at 0°C has 32554\$\Omega\$. With 3.9mA is dissipating 500mW but to do that, a supply of 126V is needed. So why are they putting 100% of Pmax? Is for other parts of lower resistance in the same datasheet? Are they not so precise because normally you use those NTC for measurement and are never used with such power?
