Just after a little clarity on something, although I think I'm on the right track.
I'm making a constant current circuit (based on the on on the eevblog) which uses a Mosfet and a 1 ohm resistor and I want to ensure that the chosen Mosfet will be within it's operating range. The circuit currently produces 2v after the Mosfet (at the source pin) and I'm assuming that any extra voltage present before the mosfet (at the drain pin) needs to be dissipated as heat.
So if my understanding is correct, with a 5v input voltage I'll need to drop 3v and at 2 amps that's 6watts of power that needs to be dissipated.
This sounds pretty simple. Maybe there's more to it, but for a simple ballpark figure is this good enough?
Thanks
Jase
