One thing that puzzles me is how this is possible. I shorted glass fuses several times, they blew instantly. Not even a spark was visible. The only way I see fuse don't open is when somehow evaporating wire inside the fuse turns into plasma or something. But I thought it's more danger for DC, not for AC as plasma disappears at zero crossing.
So, how can a glass fuse conduct under overcurrent condition?
By being a neat little glass tube full of metal vapour. If you consider how readily a column of non-conductive gas (Neon discharge tubes, xenon discharge tubes, lightning in air etc) will conduct electricity once you get it hot enough, how much more enthusiastic to carry current is the vapour phase of something that was already a conductor at room temperature going to be?
It's a misnomer that plasma discharges necessarily disappear at zero crossings. That only happens if there's enough off time passes that the plasma system cools to below the temperature that it is a plasma. Fluorescent discharge tubes run quite happily on 50/60Hz AC as we all know from experience.
Fortunately the 'perfect storm' necessary for a puny 5x20mm glass fuse to turn into a raging torrent of plasma is rare or we'd all have horror stories of equipment bursting into flames because of them. However, it can happen and as the manufacturer's data shows the
guaranteed breaking capacity of 5x20mm glass fuses is low. That doesn't mean that they
will fail to operate correctly at higher fault currents, just that it is a possibility - one that is easily avoided by paying 2p more for an HRC fuse.
Also bear in mind that the
guaranteed breaking capacity is more prosaic than preventing the perfect storm. All a fuse has to do to fail dangerously is to leave equipment live that ought to have been isolated, even if that is under circumstances where a failed 'blown' fuse is simply carrying less current after failing than before failing - it ought not to be carrying any current at all. You can start a fire with a smouldering bit of insulation, it doesn't require a can of petrol and a flare or a 6kA plasma arc.
