STORYTIME!!
So I have this 1 watt LED that I power directly from the 3.3v output of my Arduino Uno. It draws.... let me check.... Oh, sh*t the 3.3v output is broken... (it drew around 300mA) let me explain. I got this 20 watt led in the mail today and I connected up one of
these buck-boost converters to my Arduino, set the output to 32+ volts and hooked up the LED... It worked, but I was dismayed to find that it only drew around 80mA from the output.... WHAT???
It was also a bit brighter than the 1 watt led, and it didn't heat up at all (of course it didn't, it was only drawing 80mA for god's sake). I checked the
input of the converter and found that it was drawing around 800mA. Then, just for testing, I shorted the converter and got around 1A+ on the output. Then the Arduino stopped providing power and then I found that it had heated up in the area of the voltage regulator... after a bit of fiddling it came back to life, but as I discovered earlier, the 3.3v rail was dead. Anyway, side question, why did that happen? Moving on.
I am pretty confused, the output of the boost converter shows that it is capable of delivering 1A+... So why doesn't the LED draw that? And how can that beast of a LED outdo the 1 watt LED with less power usage and less heat? I have two of those DC-DC converters, should I wire them up in series and put 15v on each, and connect them to different power sources? Will that make a difference? (I did some research on putting multiple DC-DC converters in parallel, and learned that it is a bad idea). What should i do? What is the best way to power the 20 watt LED?
