Thanks for all of the replies!!!
HalfSpace, it seems that most lipo batteries used today are 3.7v per cell. It would probably be best to just have a single cell and boost it up to the required voltage with a dc-dc converter. I read what you wrote as saying that I should connect both the charging circuitry and the load directly to the battery and simultaneously charge and discharge the battery - however I may be wrong, but if that is what you meant then this is why I am hesitant: from what I've seen on the internet, when you both simultaneously charge and discharge a battery (in this case charging the battery from 48v PoE being stepped down to the charging voltage and being discharged by the Arduino and door striker) it does work; however it is seen as a bit of a hack as you are constantly running the battery, degrading its life and performance more rapidly over time. Regarding the Arduino's voltage regulator, the idea of wasting the 7v (12v input - 7v from volt reg to yield 5v for Arduino) sorta annoys me
. However, I have been thinking recently (
) that it would be a good tactic to use a dc-dc converter to do the heavy lifting and bring whatever voltage (probably 12v) down to about 7v and then run it through a voltage regulator and get a much cleaner 5vdc.
Whales, I plan on using PoE in accordance with 802.3af, so it would be running at a nominal 48v. Thats an interesting approach. I was initially going to do that and design a little logic circuit or something and then use some MOSFETS to switch all of the power. I don't really think that it would be too difficult. The thing is that I began to read up on these PMIC's and got swayed a bit, they seem perfect for my situation but I just get lost in their data-sheets. I will make a circuit that should do the job but I would still love to see how to use one of these little power management ic's. Thats a good idea to place a decent capacitors across the power rail (btw, would this be an example of a decoupling capacitor or is there another name for it?).
Retrolefty, your correct in identifying safety as a big thing. There are multiple things that make this system rather safe:
1. the doors only stop people from entering a door, not exiting. So in the event of a power outage or natural disaster or even a complete system failure people can still exit the building.
2. the purpose of the lipo battery is to provide power to the system and give some up-time (potentially quite a bit) so people can get in and collect what they have to in the event of a power loss situation
3. in a situation where security wasn't as important as convenience (for example a bed room door lock) a door striker that opens upon power loss could be used
Marco, the door striker is pretty robust. I guess it could take a lot more voltage, but I don't understand what advantage is gained by overvolting it. A 3.7v single-cell lipo pac is currently my number 1 choice, however, that is subject to change if an advantage can be gained from another solution.
Again, Thank You all for the replies
