Sorry if this has been asked before. I am trying to figure out a good way of turning on a microcontroller with vibration for a low power / battery operated application. I came across some cheap switches like SW-18020P, which has different sensitivities. Could be used as an input to some kind of latching power circuit? It would need to allow the MCU enough time to keep the latch on or some or enable pin, then it would be able to turn itself. Perhaps the circuit could also allow for the MCU to check if it is still being vibrated. I did some searching, but I did not really find a good example, but there are probably some out there...
