== short version ==
I need help interpreting the markings on this GU-SS-124DFS relay wrt to its datasheet.
== long version ==
My friend, in Canada (120V AC), has a bad relay in a vending (pop) machine. A picture of it is included.
According the Goodsky datasheet that I found (attached), the following GU-SS-124DFS markings mean for
Type:
GU = Quick Contact Tab
Type of Sealing:
SS = RT ? Flux Proofed Relays
Number of Pole:
1 = One Pole
Coil Voltage:
24 = 24V coil
Coil Type:
D = Standard DC Coil
Contact form: =
nil One Form C
Terminal Type:
F = Both PCB Terminal & Quick Contact Tabs
Case Type:
S = With Flanged Case
Insulation System:
nil Standard Class
Since the Contact form is nil (one form C), that implies it is a SPDT as per datasheet.
Here is where I'm confused.
In the Contact Rating table, page 1, under the column GU (D), it specifies
NC: 10A 240VAC
NO: 20A 240VAC
However, the photo shows
NC: 20A/240VAC
NO: 30A/240VAC
The website to
http://www.goodsky.com.tw/is always down when I try to access it to find more information.
Question 1) Which is correct? The datasheet or the markings on the actual relay?
Question 2) If the photo is correct wrt to the contact ratings, then a search on mouser with the following parameters 30A relay, 24VDC coil voltage, SPDT, quick connect terminal yields 3 suitable candidates with W9AS5D52-24 being the most likely match.
http://www.mouser.com/ds/2/357/105A_W9A-180345.pdfHowever, the datasheet (attached) specifies
NC: 15A/240VAC
NO: 30A/240VAC
Is the NC at 15A something to worry about? My friend has no means of measuring the amperage when the vending machine is running. He doesn't live in my city so I have no way of measuring it either.
