TiTanerCZE...What you say sounds normal……..you want to set a certain voltage, but you dont want to be supplying more than a certain current, so you set the CL….then, if your load trys to draw more than the CL value, the power supply just clamps the current at the CL value, and of course, if the load stays heavy, the output voltage will fall, ….it falls because the load is now too heavy for keeping the vout at that level given the CL value that you have set.
It works by there being two error amplifiers……one is the output voltage error amplifier..and this works under normal case….but your current sense is always in there, and when that current trips the current limit threshold, then the current error amplifier kicks in, and as long as the too_heavy load stays on, the current is clamped to the CL level…………..the voltage must fall because you have limited the current………..there isn’t enough current to keep the supplies output capacitors topped up and supply the load…so the voltage must fall….what actually happens is the voltage error amplifier gets railed, and is out of the picture, at least until the load gets lighter.
