your looking for an op amp whose input and output include the lowest and highest voltage you need, being how its a pwm signal i presume you will be filtering it back to near DC, in which case slew rate wont be all that critical, if your looking for precision look for a low input offset voltage,
realy to spec any specific one you need to give us some more details like the voltage range,
