Is there any reason I couldn't take a 12VDC power supply, use a 5VDC regulator to give me 12VDC, 5VDC, Gnd, and treat it as if it were +7VDC, Gnd, -5VDC?
If this is the case, why would you then use a single rail OP Amp and bias the input to it, since you have to then filter the DC at in and out?
Sent from my XT1039 using Tapatalk
