It would work in a way, but there is an implicit ground not marked on the diagram. The output waves are going to be referenced to 0V so they swing symmetrically positive and negative as AC signals. If you powered the circuit from a 0 to +30 V supply the output signals will be DC biased to +15 V. This most likely is not what you need.
