Author Topic: power transformer to audio output transformer  (Read 2333 times)
Offline christosTopic starter
  • Country: gr
« on: March 28, 2014, 05:55:41 pm »
as the title says..can i make a power transformer 230v to 6-0-6v as a audio output transformer??if i can..then would the secondary coil be the input of the audio?
Offline woodchips
Re: power transformer to audio output transformer
« Reply #1 on: March 28, 2014, 06:51:57 pm »
Presumably valve? Not if class A, there is substantial DC current flowing that will saturate the transformer, fizz, pop!
I have never tried it, one day, but for class B why not? The DC currents should be equal and opposite so cancel, leaving the transformer happy. A toroidal transformer will be better than an EI type for frequency response. Might even be possible to use a thin cutting disc to make a slot so usable on class A?
Have wondered why you can't use a standard transformer, and buck the DC current with an opposing current through another winding. Seems a reasonably simple bit of servoing, measure HT DC current and then provide the exact opposite? Will it work? Why not?
« Reply #2 on: March 28, 2014, 07:10:24 pm »
Try looking for 100V line transformers, they might be capable of handling DC through the primary. If you use a transformer with 2 115V primary windings and run the valves in push pull with a 100V HT rail then the current will cancel out in the core and you will get better linearity.
  • Country: gr
« Reply #3 on: March 28, 2014, 07:31:57 pm »
hard to find a 100v...i just wanned to know if its possible..if not ill buy one..5 euros only
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: March 29, 2014, 03:05:52 am »
Again, assuming this is for valves/tubes (you didn't mention), you can use a 115-0-115 primary in a PP circuit with reasonable results.
Unless it's a toroidal type, don't expect useful bandwidth.
Seven Transistor Labs, LLC
Tac Eht Xilef
  • Guest
« Reply #5 on: March 29, 2014, 07:04:22 am »
This was occasionally done in very early valve radios - not really as a servo, since there was little/no feedback (at least not completely deliberately) - by incorporating the filter choke for the HT supply (usually between the CT & gnd) into the output transformer to cancel out the field caused by the DC component of the class A output stage.
It was as big a pain in the arse as it sounds...
