Author Topic: Powering mcu question  (Read 2406 times)
Offline DarkZeroTopic starter
  • Country: cs
« on: August 24, 2016, 09:17:12 pm »
i wanted to build a small current meter panel and i stole Dave's design, now i want to use same power supply that powers the op amps for the mcu without messing the things about the GND i simply cannot wrap my mind around it plz some suggestions
Offline danadak
Re: Powering mcu question
« Reply #1 on: August 24, 2016, 11:00:05 pm »
Several issues/solutions -
1) I assume the MCU CM range is + only with respect to its ground. Therefore
the OpAmp feeding MCU input has to be offset appropriately to force this to
happen. Easy with a R network to gen the offset.
2) MCU tied to ground as shown in schematic.
3) Assuming MCU is 5V, then use a 2.5V zener from the positive supply source
to MCU, one approach. 7.5 - 5V (assuming MCU is 5V) = 2.5V
4) Or use a 3 term adj reg, gnd leg to - side 15V supply, input to + side of 15V supply,
set it to 7.5 + 5 (assuming MCU is 5V) = 12.5V, and reg output goes to MCU Vdd pin.
Regards, Dana.
« Last Edit: August 24, 2016, 11:02:50 pm by danadak »
Offline danadak
« Reply #2 on: August 24, 2016, 11:45:13 pm »
One consideration is U2 has to carry the MCU Vss ground leg current. Since it is
7.5V above supply - leg for every 1 mA of MCU Vss current the OpAmp has to dissipate
7.5 mW. So do a current budget on MCU and all its I/O load that flows thru its ground
pin and calc Pdiss. If too much for OpAmp consider a power OpAmp, or another 3 term
reg to establish the system ground potential. Note that reg would have to have a source/
sink output capability, not in every 3 term reg.
Also, for stability, if you use large C bypass from + or - supply to ground, examine OpAmp
datasheets for C loading limitations. If necessary add a zero into OpAmp feedback net to
lift the phase to get adequate phase margin.
Regards, Dana.
« Last Edit: August 24, 2016, 11:52:27 pm by danadak »
Offline rstofer
« Reply #3 on: August 24, 2016, 11:58:05 pm »
Section 4.3 of Op Amps For Everyone:
http://www.cypress.com/file/65366/download
Basically you use a 5V single supply rail to rail op amp to offset and scale the input to match the range of the MCU.
  • Country: cs
« Reply #4 on: August 25, 2016, 05:27:12 pm »
my whole circuit draws 75mA max but ill take it that's it's 100mA so i guess i can get away with 150mA supply. so either i find some op-amp that can source or sink 100mA or i get some chip that can do -V because i don't want to use transformer with 2x secondary.
but let me ask maybe a stupid question is it possible to boost current capability with a transistor in this situation ?  or should i just wack in 7660
Offline danadak
« Reply #5 on: August 25, 2016, 10:32:20 pm »
Then generate a - supply, some techniques -
https://www.dropbox.com/s/k1yn4m7heaixvmg/ADinput%20negative%20inputs.zip?dl=0
Regards, Dana.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #6 on: August 26, 2016, 05:36:27 am »
Why do you need a 15v supply?
