Several issues/solutions -
1) I assume the MCU CM range is + only with respect to its ground. Therefore
the OpAmp feeding MCU input has to be offset appropriately to force this to
happen. Easy with a R network to gen the offset.
2) MCU tied to ground as shown in schematic.
3) Assuming MCU is 5V, then use a 2.5V zener from the positive supply source
to MCU, one approach. 7.5 - 5V (assuming MCU is 5V) = 2.5V
4) Or use a 3 term adj reg, gnd leg to - side 15V supply, input to + side of 15V supply,
set it to 7.5 + 5 (assuming MCU is 5V) = 12.5V, and reg output goes to MCU Vdd pin.
Regards, Dana.
