Yes there are many ppm associated with voltage references (temperature, long term drift, hysteresis, noise, initial error, line regulation, load regulation etc).
Since the OP didn't mention which one he is very likely referring to the temperature since that's how manufacturers advertise the voltage references, if you see "2.5v 5ppm reference" you can be certain that the 5ppm is the tempco.
