Kobalt is a house Lowe's brand of medium range quality. The trick to precision tools is equally the precision workmanship of the driver tip and the metal alloy used. Applying a lot of torque to the big handle won't matter if finely cut tips deform so the metal must be good quality as there is not much mass in small tool heads; that why you can find 'precision' tools as low as $3/set
in the USA that appear to look good, until you look at them closely and see the tips cut haphazardly or apply some torque to them and they snap.
Willie Hahn, aka Wiha, and many of similar quality, make their precision tools typically with chromium, molybdenum +/- vanadium steel to add the special quality to the tool, so a set of 7 Wiha drivers will run about $40, but they are truly made to take the torque for the handle they are designed to fit and are cut perfectly to fit all the screws they were designed to twist.
IMHO Wihas have never failed to fit, but rarely, the cheapo tools will not fit a supposed proper screw, that's the main difference, and when you twist a stubborn screw, most often the cheap drivers either can't do it or deform, whereas Wihas will stay true. One won't know experience this until you've open quite a number of cases, and stubborn screws are often found in soiled or contaminated devices used in commercial or military settings rather than personal devices that are not as heavily used or abused.
The other day I use a set of Kobalt screwdriver set in the pic below ... I really liked them because they where nice to use and seemed to be made of quality metal ...But what do you guys think of the set for the price ?
http://www.lowes.com/pd_115462-86580-SF3B_4294857616__?productId=3276987&Ns=p_product_avg_rating|1
