WD40 and copper is not a good idea, it will result in a lot of green crud with time. It is noted in the data sheets not to use on brass, as it will damage it long term. wWorks fine on steel, keeping it reasonably free of corrosion in a semi controlled atmosphere.
Best is sealed in a non permeable laminated vapour proof bag, with a sachet of desiccant in there, and wrapped with each sheet of PCB in acid free kraft paper, all with a overpack inside of plastic lined wax paper. That will, provided it is not opened, or is resealed very fast after a careful open ( make a long end so you can do a number of seals before needing a new bag) and quick removal of the needed quantity, last for decades.
Another method is to dip the clean boards in hot paraffin wax, and then into a waxed paper cover, and then place the whole lot in more waxed paper and then finally in a vapour proof bag. Nuts , bolts and complete delicate assemblies preserved that way come out looking like new after a quick boiling in solvent to get the wax off.
