Author Topic: PRINTING WITH LTSPICE  (Read 11520 times)
Offline neko efecktzTopic starter
« on: November 01, 2016, 01:20:42 am »
Good day all,
I have just installed LTSpice to simulate a couple of projects.
I'm finding it quite a powerful tool.
David did a demo video of how to get started using it, Very helpful.
I am unable to print properly to my laser printer.
All text and labels print Ok but components and wiring are very faint.
There is a "PRINT MONOCHROME" option in the file menu but this does not work correctly .
I can print Ok to my HP Colour / Color printer in either Colour or Mono Chrome.
I can print to Microsoft PDF writer and then print to the laser printer Ok but the pdf writer does not start automatically and I need to find the PDF file, open it, then print.
Does anyone know how to solve the problem.
I am heading to work soon and won't find your replies until tomorrow morning.
Thank you
BILL.
Offline AlfBaz
Re: PRINTING WITH LTSPICE
« Reply #1 on: November 01, 2016, 05:22:22 am »
You could try changing the colour preferences, see if that makes a difference. For example white back ground with black lines and symbols
It's under tools-> color preferences
Online Zero999
  • 0999
« Reply #2 on: November 01, 2016, 10:27:20 am »
I have the same problem.
I normally export to EMF and print that.
« Reply #3 on: November 01, 2016, 10:49:41 pm »
Thanks AlfBaz and Hero999.
I forgot to mention that I had already tried changing all colours to black using TOOLS ==> COLOR PREFERENCE ==> All colours 0,0,0.
This had no effect.
I also tried MS XPS writer.
Think I'll have to keep using MS PDF writer.
EDIT... is there a way to mirror a component, not rotate.
To keep the component Ie. an OP Amp facing the same way but to reverse the input positions.
Thanks again for your help.
BILL.
« Last Edit: November 02, 2016, 01:20:09 am by neko efecktz »
Online Zero999
  • 0999
« Reply #4 on: November 02, 2016, 08:59:24 am »
I also tried changing the colours and the lines to thick but it had no effect on the printing.
Yes, whilst moving/placing a component ctrl+r rotates, and crtl+e mirrors. Beware that if you flip the op-amp upside down, the power supply pins will be reversed.
Offline BravoV
  • +++ ATH1
« Reply #5 on: November 02, 2016, 09:19:11 am »
Attached 3 printed schematic in PDF using Bullzip PDF Printer, but on LTSpice XVII though :
1st Using the default color scheme
2nd As for testing, I changed the junction to red while component body to pink.  :P
3rd As 2nd one, this time I changed the "wire" / connection line color to black.
The "wire" or connection line always printed at very thin line.
« Last Edit: November 02, 2016, 09:22:36 am by BravoV »
Offline rstofer
« Reply #6 on: November 02, 2016, 03:31:00 pm »
There is an excellent LTSpice group on Yahoo groups.  A couple of the guys are true experts and are plugged in pretty tight with the author.
https://beta.groups.yahoo.com/neo/groups/LTspice/info  I hope the link works for non-members but I have no way to test it.
« Reply #7 on: November 05, 2016, 05:12:20 pm »
Tools/Control Panel/Drafting options/Pen thickness - would seem to be what you're looking for.
Offline BravoV
  • +++ ATH1
« Reply #8 on: November 05, 2016, 05:21:09 pm »
Nope, print result is still thin line, that setting doesn't affect print output, only at onscreen capture at copy to clipboard or write to EMF file.
« Reply #9 on: November 06, 2016, 12:56:53 am »
Glad I'm not the only one with strange things happening
The only way I am able to get a clear print is to print to PDF or to my HP colour printer even as monochrome is ok.
Is it other printers that have the problem.
My laser printer is a BROTHER HL2140.
BILL.
Offline B-17
« Reply #10 on: November 08, 2016, 03:14:29 am »
Not sure if I'm way off on this, but just using Print Preview - I can get a relatively clear view of the simulated traces/variables.
Is there anything wrong with just using the PDF--> Print? Are you just looking for a way around this?
I've usually just done the PDF route if my printer is having issues, would say this is on the less-than-ideal-but-it-works solution.
Anyone find how to get the traces fattened up?
Offline Cliff Matthews
    • General Repair and Support
« Reply #11 on: November 08, 2016, 09:35:21 pm »
If it were possible, I vote for EEV blog to absorb that group before Verizon kills it next year (still can't fathom why they turned-down the hefty offer from Microsoft 8 years ago).
