Confusing? Its brutaly simple,let me try again,there is 1000000 V voltage source and and I have 1:1000000 probe rated for 1V maximum voltage,can I use it?
If the 1V maximum voltage rating is for the probe tip,then I cant use it.If the 1V maximum voltage rating is for voltage divider output then I can use it becose 1000000 V through 1:1000000 divider is 1V.
My point is,does the 1:X probe spec matters for maximum input voltage? If I have 100V rated probes,and one is 1:2 and other 1:10,is the maximum input voltage same,or does thr 1:10 have 5x higher maximum input voltage than 1:2?
