After several years of using my bench psu, today I have noticed that the output of my toroidal transformer is floating at 80V AC above ground because ground terminal is not connected to mains ground (floating psu). Measured one EI trasnformer and metal frame is also floating at ~60V AC, but the low side output is at 1-2V respective to mains ground. That's not a problem, because the transformer core should be grounded, and the secondary side is ok, but i think that my toroidal transformer is faulty. What do you think?
Is there a way to protect the output of a floating psu in case of the faulty transformer (failed isolation between primary and secondary side)? This is not a problem for a mains grounded minus (DC ground) terminal on non floating psu.
Regards!
