Hi everyone,
I'm currently working on a linear bench power supply design. I have a five-tap (single-winding) transformer I'm hoping to use for this project, similar to multi-tap transformers used in classic linear bench power supplies where the input voltage is switched to minimise power dissipation in the pass device at low voltages and high currents.
The obvious answer is of course multiple window detectors with some hysteresis to switch in the next tap when a minimum threshold is reached, but I was hoping for a slightly simpler and more elegant solution.
Is anyone aware of an IC with programmable multiple-voltage thresholds? I'm thinking there might be something that uses a resistor ladder to set multiple thresholds that trigger corresponding output pins.
One thing that came to mind was the classic LM3914 bar-graph IC, but unfortunately it does not suit my purposes because the taps are not all equal voltage, nor are they logarithmic, so the LM3915/LM3916 are out too.
If anyone can make any suggestions, it would be greatly appreciated!
