Hi
I am programming a EEPROM with a Arduino Mega, i have two EEPROM types, ATMEL AT28C64B, that works fine, reading and programming works, but the other one a CAT28C65BP only is possible reading, i check the programming software proteccion on the two types, on the ATMEL i can activate and desactivate the software proteccion.
//Lectura
//mostrando los datos de cada direccion por medio del leds
//Definimos puerto de direcciones
#define A0 2
#define A1 3
#define A2 4
#define A3 5
#define A4 6
#define A5 7
#define A6 8
#define A7 9
#define A8 10
#define A9 11
#define A10 12
#define A11 32
#define A12 33
#define A13 34
#define A14 35
#define A15 36
#define W_enable 38
#define ReadWrite 39
#define Out_enable 40
#define Chip_enable 41
//Definimos puerto de datos
#define D0 22
#define D1 23
#define D2 24
#define D3 25
#define D4 26
#define D5 27
#define D6 28
#define D7 29
long addr=0;
byte datosmem=0;
int contador=0;
int datos=0;
void SetAddress(long a){
digitalWrite(A0, (a&1)?HIGH:LOW );
digitalWrite(A1, (a&2)?HIGH:LOW );
digitalWrite(A2, (a&4)?HIGH:LOW );
digitalWrite(A3, (a&8)?HIGH:LOW );
digitalWrite(A4, (a&16)?HIGH:LOW );
digitalWrite(A5, (a&32)?HIGH:LOW );
digitalWrite(A6, (a&64)?HIGH:LOW );
digitalWrite(A7, (a&128)?HIGH:LOW );
digitalWrite(A8, (a&256)?HIGH:LOW );
digitalWrite(A9, (a&512)?HIGH:LOW );
digitalWrite(A10, (a&1024)?HIGH:LOW );
digitalWrite(A11, (a&2048)?HIGH:LOW );
digitalWrite(A12, (a&4096)?HIGH:LOW );
digitalWrite(A13, (a&8192)?HIGH:LOW );
digitalWrite(A14, (a&16384)?HIGH:LOW );
digitalWrite(A15, (a&32768)?HIGH:LOW );
void SetData(long a){
digitalWrite(D0, (a&1)?HIGH:LOW );
digitalWrite(D1, (a&2)?HIGH:LOW );
digitalWrite(D2, (a&4)?HIGH:LOW );
digitalWrite(D3, (a&8)?HIGH:LOW );
digitalWrite(D4, (a&16)?HIGH:LOW );
digitalWrite(D5, (a&32)?HIGH:LOW );
digitalWrite(D6, (a&64)?HIGH:LOW );
digitalWrite(D7, (a&128)?HIGH:LOW );
//Funcion para leer datos
byte ReadData()
byte b = 0;
if (digitalRead(D0) == HIGH) b |= 1;
if (digitalRead(D1) == HIGH) b |= 2;
if (digitalRead(D2) == HIGH) b |= 4;
if (digitalRead(D3) == HIGH) b |= 8;
if (digitalRead(D4) == HIGH) b |= 16;
if (digitalRead(D5) == HIGH) b |= 32;
if (digitalRead(D6) == HIGH) b |= 64;
if (digitalRead(D7) == HIGH) b |= 128;
return(b);
void setup() {
// put your setup code here, to run once:
Serial.begin(9600); //Inicio puerto serial
pinMode(13,OUTPUT); //Configuro salidas direcciones
pinMode(A0,OUTPUT);
pinMode(A1,OUTPUT);
pinMode(A2,OUTPUT);
pinMode(A3,OUTPUT);
pinMode(A4,OUTPUT);
pinMode(A5,OUTPUT);
pinMode(A6,OUTPUT);
pinMode(A7,OUTPUT);
pinMode(A8,OUTPUT);
pinMode(A9,OUTPUT);
pinMode(A10,OUTPUT);
pinMode(A11,OUTPUT);
pinMode(A12,OUTPUT);
pinMode(A13,OUTPUT);
pinMode(A14,OUTPUT);
pinMode(A15,OUTPUT);
pinMode(W_enable,OUTPUT);
pinMode(ReadWrite,INPUT);
pinMode(Out_enable,OUTPUT);
pinMode(Chip_enable,OUTPUT);
delay(50);
void loop() {
// put your main code here, to run repeatedly:
if (digitalRead (ReadWrite)==0){ //Cero para leer
//Configuro entradas pines de datos
pinMode(D0,INPUT);
pinMode(D1,INPUT);
pinMode(D2,INPUT);
pinMode(D3,INPUT);
pinMode(D4,INPUT);
pinMode(D5,INPUT);
pinMode(D6,INPUT);
pinMode(D7,INPUT);
digitalWrite(W_enable,HIGH);
digitalWrite(Chip_enable,HIGH);
digitalWrite(Out_enable, HIGH);
Serial.print("0\t1\t2\t3\t4\t5\t6\t7\tAddress");
Serial.println(" ");
while(addr<32) //Lee hasta la posicion anterior
{ //a la direccion puesta
SetAddress(addr);
delay(1);
digitalWrite(Chip_enable,LOW);
delayMicroseconds(10);
digitalWrite(Out_enable,LOW);
delay(1);
datosmem=ReadData();
digitalWrite(Out_enable,HIGH);
Serial.print(datosmem);
Serial.print("\t");
addr=addr+1;
contador=contador+1;
if(contador==8)
Serial.println(addr);
contador=0;
else { //Si ReadWrite es 1 ejecuto codigo abajo
/////////////////// ESCRITURA///////////////////////////////////////////
pinMode(D0,OUTPUT);
pinMode(D1,OUTPUT);
pinMode(D2,OUTPUT);
pinMode(D3,OUTPUT);
pinMode(D4,OUTPUT);
pinMode(D5,OUTPUT);
pinMode(D6,OUTPUT);
pinMode(D7,OUTPUT);
digitalWrite(Out_enable,HIGH); // High:pines datos ENTRADA / Low:pines datos SALIDA
SetAddress(5461);
SetData(170);
digitalWrite(W_enable,LOW);
delay(5);
delay(5);
SetAddress(2730);
SetData(85);
delay(5);
delay(5);
SetAddress(5461);
SetData(160);
delay(5);
delay(5);
SetAddress(addr);
SetData(datos);
//datos=datos+1;
delay(5);
delay(5);
Serial.print(datos);
Serial.print("\t");
addr=addr+1;
if(contador==8)
contador=0;
while(true)
digitalWrite(13,HIGH);
Can anybody helpme to know what is happening to fail the programming on the CAT28C65.
Thanks in advance.
