Author Topic: Programming in C  (Read 9210 times)
Offline hlavac
  • Country: cz
Re: Programming in C
« Reply #25 on: April 10, 2013, 06:53:23 pm »
Proper understanding of C programming comes from understanding machine code/assembly level.
Only then will you know what does the CPU have to work with and what makes certain things faster than others.
Then you will see what C really does for you and appreciate it fully :)
Simple things like static type checking that without that deeper knowledge seem like unnecessary burden and compiler dumbness that should be removed suddenly start making sense...
Good enough is the enemy of the best.
Offline seb1982
« Reply #26 on: April 10, 2013, 07:08:57 pm »
Although it opens as a small window it can be maximized
Yeah, but that means I have to click a whole button!   ;)
Smoking and melted? It was like that when I got here.
