Either the output driver is shorted as suggested above, or the receiver has forgotten the transmitter (less likely unless you held the rx button as below!)
Typical operation:
The LED flash when you press a Tx button is simply saying it received a key, but other than 'opening' the relay, there is usually no other indications for a successful key press.
CAREFUL. If you hold the receiver button down for an extended period, it's will 'erase' all known Tx keys...!
Learning is usually - press the Rs button once quickly (sometimes a 'learn' LED will light up, then press a Tx key within 5-10 secs to memorise the key.
