Thinking about it further, and doing continued research, one PC might be enough after all, if I really invest a lot into it. I have two more separate builds, with the only difference between them being the processor.
In that case, my last few posts can be completely ignored unless there would be something useful to add back there...
Question 1: In the more expensive build, would those two dual processors be worth the total price tag of $10,000-$11,000 of a computer build over the $7,000-$8,000 computer build with lower grade CPU processors instead.
Question 2: Is the 1080 GPU really faster for my specific needs (as I am not focused on gaming speeds) than the 980 Ti or the Titan X? The price tag must have some sort of meaning, at least between these, as it should be a difference between consumers and business for this price range.
I see that the memory bandwidth is higher on both the 980 Ti and the Titan X. Will that support my build better for it's purpose, or is it an insignificant difference showing little improvement over one another?
Most expensive build... $10,000-$11,000 including taxes, and my customized case.
https://pcpartpicker.com/list/XVbqwVSecond most expensive build... $7,000-$8,000 including taxes, and my customized case.
https://pcpartpicker.com/list/wzWxVY
