I'm not sure exactly what you mean?
I think I have my workflow basically ironed out at this point. It's a workflow I already have adapted to, more or less. I'm trying to upgrade the business to a more commercial/professional level, but it is something that has been in place for a few years now.
I don't believe I have changed anything necessarily, these are all additional options, or alternatives that others have suggested to me, that I have been taking into consideration. If someone can figure out something better than anything I have in mind, that is really what I have been looking for on that end.
I've explained a few times, the workflow basically consists, of continuously editing videos/video games/music with no slowdown. That has been the priority since the beginning, I have only changed the concept of doing this on single computers.
Going off of my original first post, I was proofreading what I had thought was a suitable build, and I was intending to build quite a few of them 4-5, in order to make the workflow of me and my team hopping between them, which was really too complicated. I did not explain that clearly before, but I never felt it necessary, because we moved rather quickly to the idea of two separate builds.
With the two separate builds in mind, the workflow basically means what it originally did, which is why I want the network configuration to make it as if it really were one computer I was working on, instead of two, with the added benefit of no rendering slowing that workflow down, by forcing me to stop working.
I can be more specifically detailed if you want me to, regarding the workflow.
By the way, I made a topic concerning the server rack specifically, not necessarily intended for these builds but for a rack of other builds, and I'm having a hard time figuring out which components I would need to get this done with, if anyone is interested in sharing their expertise over there?
https://www.eevblog.com/forum/beginners/finding-an-inexpensive-42u-server-rackwith-shelves-in-the-pennsylvania-area/msg1125925/#msg1125925
