Hi, thanks for the reply and suggestions!
The solenoid draws around 6mA at 30V.
If I were to go with something like a SPDT relay to switch between either the magneto or H bridge, as the signal voltage for the solenoid, would that pretty much get the job done? Would I even need to worry about opto-isolation, or other forms of protection at that point?
Thanks again!
