I got an odd ball custom built PSU at a rally yesterday, for virtually nothing. Apparently custom built for some testing purpose in a production environment it basically consists of a computer SMPS unit in a nice case, with a bespoke PCB. feeding panel sockets. It appears in use it had USB control of some functions, and also has a serial port. The grey wire out the front of the panel terminates in a USB plug. The computer SMPS outputs are fed to the custom PCB and there are banana sockets on the front panel for +15V, -15V, +12V, -12V, +5V and -5V.
I am seeing the following under test from these sockets, in the same order as above: 11.6V, -0.1mV, 12.16V, -11.3V, 5.05V and -5.04V
I am guessing the 15v is derived from a DC to DC converter circuit from 12V perhaps, and that's what the coil and choke are for? You can see photos at
http://www.chriswilson.tv/psu/psu.htmlI will try and attach a few below, too. There are also some small IC's with two loops of insulated wire around them, and I have never seen anything like that before, any ideas why they have done this?
I was going to use the supply (forgetting about USB /serial control) just to run breadboard experiments using OpAmps that need + and - 15 rail supplies. Without a circuit diagram I need assistance with ID'ing what part of the circuit may be at fault. The SMPS itself outputs sensible voltages to the PCB, although (assuming it's even used) the -12V is low at around -11.3V. I suspect they may have got the split 15V supply with a resistor divider network, hence perhaps the 4 big 1k resistors? Guessing though.... Thanks for any tips. I can upload more specific photos if desired.
