Good morning Everybody.
I have resolved my previous question posted yesterday.
Just a few quick questions.
What effect would it have, if any, if the output pins of a PIC namely PIC16F877A had 10K pull-up resistors.
I just built a new board using different ports to my previous one, to make better use of port C particularly I want to use the I2C option of port C.
Port C has terminals for I2C.
I made provision on Ports B & C for pull-up resistor arrays and without thinking fitted an array to each.
I was planning on using Port A is analog input, already set up and working, Port B as Input, Port C for Output including I2C, Port D is set up for the 1602 LCD and Port E is not committed.
Is there any advantages in using Port B or Port C as input or output? which way would you go? Please keep it clean.
I could suck out the array on Port C.
Thank you
BILL.
