Link to my first thread about equipment:
https://www.eevblog.com/forum/beginners/my-purchase-list-for-my-new-lab-budget-$1000-thoughts/Posting what components I am looking at today and could use some advice. I've included pictures in case those are easier to read (I know the text can get dense). The parts I am focusing on are more the actual pieces that are used on the board, connectors, leads, protoboards, wire, etc, things I have not yet purchased. Thought it would be easier to make a new thread since the focus is quite different.
Here is what I've looked into getting so far:
Resistors:30 values, 300 pieces total, 1/4W, 1% metal.
Values (10 of each): 10Ω、22Ω、 47Ω、100Ω、150Ω、200Ω、220Ω、270Ω、330Ω, 470Ω、510Ω、680Ω、1KΩ、2KΩ、2.2KΩ、3.3KΩ、4.7KΩ、5.1KΩ、6.8KΩ, 10KΩ、20KΩ、47KΩ、51KΩ、68KΩ、100KΩ、220KΩ、300KΩ、470KΩ、680KΩ、1MΩ
Values (picture instead)
https://www.ebay.com/itm/112341051881 (3 packs of the above)
64 values, 1280 pieces total, 1/4W, 1% metal
Values (20 of each), picture:
https://www.ebay.com/itm/261374861457 (1 pack)
Ceramic Capacitors:50 values, total 1000 pieces
Values (20 of each): 1 pf (1), 2 pf (2), 3 pf (3), 4 pf (4), 5 pf (5), 6pf (6), 7pf (7), 8pf (
, 9pf (9), 10pf (10), 15pf (15), 18pf (18), 20pf (20), 22pf (22), 27pf (27), 30pf (30), 33pf (33), 40pf (40), 47pf (47), 50pf (50), 56pf (56), 68pf (68), 82pf (82), 100pf (101), 120pf (121), 140pf (141), 150pf (151), 180pf (181), 220pf (221), 300pf (301), 330pf (331), 470pf (471), 560pf (561), 680pf (681), 820pf (821), 1nF (102), 1.5nf (152), 2nf (202), 2.2nf (222), 3.3nf (332), 4.7nf (472), 6.8nf (682), 10nf (103), 15nf (153), 20nf (203), 22nf (223), 33nf (333), 47nf (473), 68nf (683), 100nf (104)
https://www.ebay.com/itm/122542633519 (1 pack)
Electrolytic Capacitors:25 values, 125 pieces total
Values (5 of each): 16V/47uF, 16V/100uF, 16V/220uF, 16V/470uF, 16V/1000uF, 25V/10uF, 25V/47uF, 25V/100uF, 25V/220uF, 25V/330uF, 25V/470u, 25V/1000uF, 25V/2200uF, 50V/1uF 50V/3.3uF, 50V/4.7uF, 50V/6.8uF, 50V/10uF, 50V/33uF, 50V/47uF, 50V/100uF, 50V/220uF, 50V/330uF, 50V/470uF, 50V/1000uF
Values (picture instead):
https://www.ebay.com/itm/152015420230 (1 pack)
Polyester/Film Capacitors:18 values, 180 pieces total
Values (10 of each): 2A471J, 2A102J, 2A152J, 2A182J, 2A222J, 2A332J, 2A472J, 2A562J, 2A682J, 2A103J, 2A153J, 2A223J, 2A333J, 2A473J, 2A563J, 2A683J, 2A104J, 2A224J
https://www.aliexpress.com/item/-/32857807794.html (1 pack)
Diodes:14 values, 200 pieces total
Values:
Rectifier Diode: 20 * 1N4001 (1A 50V), 20 * 1N4004 (1A 400V), 20 * 1N4007 (1A 1000V), 10 * RL207 (2A 1000V), 10 * 1N5404 (3A 400V), 10 * 1N5406 (3A 600V), 10 * 1N5408 (3A 1000V)
Fast Recovery Diode: 10 * UF4007 (1A 1000V), 10 * FR107 (1A 1000V), 10 * FR207 (2A 1000V)
Switching Diodes: 30 * 1N4148 (200mA 100V)
Schottky Diodes: 10 * 1N5817 (1A 20V), 20 * 1N5819 (1A 40V), 10 * 1N5822 (3A 40V)
https://www.ebay.com/itm/273315944592 (1 pack)
LEDs:5 colors (red yellow green blue white), 2 sizes, 150 pieces total (3V, 20mA)
(Basically 15 of each)
For red, yellow, green, 3mm and 5mm, it is 2V, 20mA, forward voltage 2 - 2.2V.
For blue, white, 3mm and 5mm, it is 3V, 20mA, forward voltage 3 - 3.2V.
https://www.ebay.com/itm/391368927437 (1 pack)
Transistors:15 value 600pcs Transistor TO-92 Assortment NPN PNP DIY kit
Picture / Values:
https://www.ebay.com/itm/222509491667 (1 pack...?)
Male to Male Breadboard Wires:65 pieces total
Values: Wire Length (include pin part): 24CM (4PCS), 20CM (4PCS), 16CM (8PCS), 12CM (49PCS)
https://www.aliexpress.com/item/High-Quality-65pcs-Male-To-Male-Breadboard-Wires-Jumper-Cable-Bread-Board-Wires/32800860317.html (3 packs...?)
Protoboards:Really unsure what's good here, but I see this on Amazon:
AUSTOR 36 Pieces Double Sided PCB Board Prototype Kit, 5 Sizes Universal Printed Circuit Protoboard with Free Box, for DIY Soldering and Electronic Project
https://www.amazon.com/AUSTOR-Prototype-Universal-Protoboard-Electronic/dp/B074X2GDH2 *******************
Anyway this is as far as I've gotten today in terms of researching various components... I'd really appreciate any feedback. Should I get different components on any of these? Am I missing any crucial things? Should I get additional packs of any of these? Are there other components / items I should get?
I haven't even looked at things like logic chips, MOSFETS (nor do I know if the transistors I have are BJT or FET... not sure what all these different categories mean yet), wire, clamps, leads, opamps(?), zener diodes(?), other things?, etc. Any guidance or advice is much appreciated. Thanks.
