Author Topic: Pure opamp integrator definition  (Read 1032 times)
Offline zzlong94Topic starter
  • Country: my
« on: November 22, 2017, 05:49:38 pm »
The definition of pure opamp integrator is also known as ideal integrator?
which means the integrator would not need a feedback resistor Rf to connect parallel with feedback capacitor, Cf?
Offline rstofer
Re: Pure opamp integrator definition
« Reply #1 on: November 22, 2017, 06:46:16 pm »
Correct, there is no resistor in the feedback path.
I use the integrator circuit for analog computing.  The input resistor is 1Mohm and the timing capacitor is 1ufd so the time constant is 1 second.  That turns out to be 'real time' for the problems I play with.
The following users thanked this post: zzlong94
Online Zero999
  • 0999
« Reply #2 on: November 22, 2017, 06:53:57 pm »
In an op-amp integrator, the capacitor is charged/discharged, with a constant current, which is directly proportional to the input voltage. The advantage over an op-amp integrator, to a plain old RC circuit, is the current flowing in/out of the capacitor is independent of the voltage on the capacitor. Of course this assumes that the op-amp's output is not saturated.
