Was finding a suitable DC/DC converter to be used in my project recently to supply a 12V input from an external 24V.
As attached is an example converter's datasheet that I came across but not quite understand.
Correct me if I'm wrong, I know the feedback voltage is to compare the output voltage with a reference voltage but I just couldn't understand how they calculate the feedback voltage. Like how they came up with the rating 1.23V as in the attachment.
I'm new to DC-DC converter and hopes someone could enlighten me, thanks.
There's an internal voltage reference inside the chip, in this case it's 1.23V. It's generated by a bandgap voltage reference in the chip.
It will be some small fixed voltage, but it's different for different chips, so you should check this value in the datasheet.
You take the voltage from the output and use a voltage divider to divide it, and this voltage enters the controller IC where it is compared against the reference voltage - so it's a feedback loop, like a servo mechanism, it makes the feedback voltage equal to the reference voltage, and the output voltage is whatever it has to be, higher or lower until that the feedback voltage matches.
So if the reference is 1.23 volts, and the voltage divider is giving a 1:10 division (in other words, say R1 = 9k and R2 = 1k) then the output voltage will be 12.3 volts.
VFB = Vout * R2 / (R1 + R2), because it's just a ordinary voltage divider.
VFB = VRef
.: Vout = VRef * (1 + (R1/R2))
You might see the same equation like that given in the datasheet for many different voltage regulators - it's the same principle.
