Hello everyone,
I'm having some doubts on some details of how a PWM signal works. I understand some of the basic knowledge, e.g. a component that is capable to withstand a maximum forward current of 100mA is able to withstand 1A if the signal has a small duty cycle.
What I am confused is about:
* This is applied for every component?
* If the maximum current rate is 100mA, I could use any current as long the Irms = 100mA? For example use a 1A with 10% D.C. ou 2A with 5% D.C.?
* Is there a frequency limit where this 10% D.C. of 1A draws more than 100mA, or it doesn't matter the frequency it will always draw 100mA? (In this supposition the components immediately rise and fall with the signal, it does not have rising or falling time)
* And the most important thing, if I use a 10% D.C. signal at 1A, do I have to use a 1A power supply or does a 100mA could be use?
