I'm not quite sure why you wanna buy what must be a common-type ballast from China but providing the tube is happy, a 32W ballast for a 20W tube should certainly give you more reliability (and light) than your 21W.
Personally wouldn't recommend going to a much higher wattage than 32W though (30% more), as you may damage the tube when starting up with the larger coil if you went to say 40W.
For example if I am changing a 4ft 40W choke (ballast), I won't go buying a 75W - 80W choke (50% more).
That said, for 7 bucks, the worst that can happen is you need to find a more powerful tube (or a slightly lower wattage choke), and you'll have learned where the limit lies with choke to tube-wattage ratio.
