It's standalone, yes.
Mind that you still need a ground between transmitter and receiver. If you're using CAT5 type cable, use shielded cable and tie the shield to circuit ground.
Otherwise, get the ground reference off the termination resistor (make a center tap), and use isolated receivers.
