On the subject of tools, what types of pliers (needle-nose and cutter?)
Given your location, I'd recommend taking a serious look at
Schmitz (they also sell through Amazon.de <
here>). You may not have heard of them, but you may have seen/had access to them as rebrands (i.e. CK Tools, Bernstein, and NWS's ESD line <yellow & black grips>).
If for some reason you can't get them reasonably, you could look into (EU brands & manufacture):
- Ideal-Tek (Swiss)
- Erem (Swiss)
- Lindstrom (Spain). Quite decent, but not what they used to be when still made in Sweden (you can do better for less money IME).
- Piergiacomi (Italian). Stamped metal types (ODM for Hakko's cutters BTW, as well as Wiha's stamped cutters). Should be easier to find in the EU than Xuron, Hakko, Xcelite,... if you want this type.
I can't recommend Schmitz enough though (equal, if not better quality than anything else I'm aware of, and at half the cost or less
They're also comfortable to use, even for extended periods of time. And as silly as it sounds, they do what they're designed for really well. Meaning the teeth on serrated pliers grab like a hungry crocodile without flattening, and cutters cut reliably for years (based on a well used pair of CK Tools cutters etched with
W. Germany I snagged off eBay). Pricing is similar to Xcelite's forged lap joint models (green handles), but you get a box joint (better than a lap for pliers), and they're a LOT more comfortable to use (longer handles, and uses dual compound grips <rubber & plastic>).
As has already been mentioned, don't abuse them if you want them to last. Namely just take care not to cut wire they're not rated for (I snapped a jaw off once by ignoring this rule
). Dropping them on a hard floor should be avoided as well (read a member snapped a tip off this way).
Tweezers:Not sure what will be available to you at reasonable prices, but generally speaking, none of these are exactly inexpensive, even if you can get around the inspection fees & import duty.
Fortunately, 2 - 3 pairs is all you really need (i.e. 5.SA + 7.SA makes a nice starter set, but a 00.SA can be nice to have as well). Some could argue to swap the 5.SA with a 00.SA (fine tip & thick tip respectively), but the finer point of the 5.SA allows you to do more IMHO (smaller packages & work better under magnification/a microscope should you find the need at some point). You just have to be a bit more careful not to damage them (more delicate).
Screwdrivers: Regarding tips holding up, there are several brands that are well liked.
- Wiha - Probably the most popular. They also offer more profiles for precision electronic screwdrivers than any other manufacturer.
- Wera - Ergonomics seem to create two distinct camps (not seen any middle ground at any rate).
- PB Swiss - Not a lot of profiles for electronics, but the best tips I've ever used. Also the most expensive.
- Felo - Reasonably priced for the quality (I'm only familiar with regular sized drivers though).
I'm guessing Wiha would probably be your best bet, should you need any screwdrivers.
Miscellaneous: Lots of small, inexpensive tools can be really handy as well.
- Hemostats
- Hobby knife or scalpel
- Dental picks, scrapers, and wax carvers (really good for cleaning solder blobs & stubborn flux deposits).
- Dental mirror
- ESD cleaning brushes (check out Gordon Brush).
- Small spring clamps (example; excellent for holding items being glued up types of tasks)
- Dispenser bottle/s (example)
Hope this helps.
